Plusnet ADSL via Linux (SuSE8.2) - any suggestions?
I am trying, unsuccesfully, to set up my Plusnet ADSL service to work via SuSE 8.2. It's not proving to be crystal clear to me exactly how to go about setting this up. Plusnet doesn't support Linux - does anyone have any suggestions please?
Cheers
Peter
How do you connect to ADSL - modem or router?
Tim
You just beat me to that question.
If its a modem are you sure that the drivers are available for Linux? If its a router is your network card setup correctly? Do you have a single IP or a block of 4 / 8?
Chris
