PlusNet - Feedback for the work you did (06/08/02)
I connect straight away now, on first attempt, less than a second!.
beofore i had to try around 3-4 times or wait longer.
Here is a test i did at ADSLguide
Starting speed test...
Do not use your connection until the test has finished.
Downloaded 32768 bytes in 656ms
Fairly fast connection, trying 524288 bytes.
Downloaded 524288 bytes in 8907ms
Now starting download test
Downloaded 524288 bytes in 9435ms
Estimated downstream speed is 434Kbps.
Uploaded 133120 bytes in 4687ms
Estimated upstream speed is 221Kbps.
Uploaded 133120 bytes in 5265ms
Overall estimated upstream speed is 209Kbps.
Results stored.
>>> Speed: 434Kbps (down), 209Kbps (up) <<<
Test complete.
ADSL Speed Typical Download Typical Upload
500 460 kbps - 220-260 kbps
I noticed in previous posts by other users, their downstream was only reported as fairly slow, mine has always reported back fairly fast, but my upstream was very very slow before, now it is reasonable again Smiley
My own tests show the upstream is alot better than it was at 6K/bs before PlusNet's work, now it's about 16-20K/bs (at the moment anyway)
Jason
RE: PlusNet - Feedback for the work you did (06/08/02)
Opps! i started to FTP again and it has dropped to 8K/bs now Sad
So Upstream is still slow, it varies.
Downstream is ok.
Jason
Another update for PlusNet
Current Downstream = 30.76 KB/s
Current Upstream = 16.41 KB/s
Using P2P @ 23:15 06/08/02
I'll keep testing for you.
Jason
>>> Speed: 421Kbps (down), 231Kbps (up) <<<
Test complete.
and again...
>>> Speed: 457Kbps (down), 233Kbps (up) <<<
Test complete.
Excellent Service, I say, Plusnet, you have got my ADSL connection performing exactly how I want it..
Great work +net, Lets hope BT get their act together and get that 155Mb "fat pipe" installed soon.
Brian.
Hi Guys,
My latest Speedtest results done at 21:06 07.08.02, peak usage time I would guess.
Downloaded 32768 bytes in 1100ms
Fairly slow connection, trying 262144 bytes.
Downloaded 262144 bytes in 4830ms
Downloaded 262144 bytes in 5762ms
Estimated downstream speed is 355Kbps.
Uploaded 133120 bytes in 5490ms
Estimated upstream speed is 189Kbps.
Uploaded 133120 bytes in 5990ms
Overall estimated upstream speed is 181Kbps.
Results stored.
>>> Speed: 355Kbps (down), 181Kbps (up) <<<
Test complete.
Much better than before! Result!
Keep it up and the new fat pipe should really make it zip like it has in the past!
Thanks,
Mines wasnt so great
Taken on 8/08/2002, this was best of 5 tries
446 Download and 87 Upload
So something is still not right with upload,
previously before the troubles I got consistently
452 Download and 180 - 200 Upload
Ali
