Plus Net E-mail....
Plus Net E-mail....
Is there a limit to how much space you can use up with your e-mails?
Is there a maximum size attachment you can recieve?
I had a look in the t&c's but couldn't find anything.
Plus Net E-mail....
IIRC, 100MB.
However, that might be the maximum send limit.
If you wish to receive more than that, there are far better mathods than e-mail.
Another method is to use multipart e-mails. The sender changes the settings to a maximum of 1024KB. The client should them split it into just over 100 e-mails.
Once all received the client should auto-maticly re-construct it into a single e-mail,
Plus Net E-mail....
Is there a limit to the size of my mailbox?
