Plug but no play
Plug but no play
Thanks for the quick response, I'll give it another try when I get home this evening.
Iain
Plug but no play
The Netgear DG834G combined router, modem firewall etc that configured last night confirms adsl connection, and the settings all seem to be in order, but there is still no connection to the web. Is there anything obvious thatI am overlooking? It is supposed to be very staightforward to set up, taking < 10 mins, but I was at it for 6 hours last night with no joy whatsoever.
Iain
Plusnet Staff
Plusnet Staff
Plug but no play
Looks like there was a problem on your account, I've fixed this for you now. Make sure the username is entered in as teabiscuit@plusdsl.net reboot your router and give it another try and it should connect first time.
