Please recomend security settings SAR110 router
Just set up SAR110 router, the default has firewall turned off, security is set to none on the port filters page, no port filters are set.
It would be helpfull if someone could briefly recomend in not-too-technical language how it should be set up to provide some security.
1 REPLY
In general as the router is doing NAT (Network Address Translation) for your connection, this provides a lot of inherent security as your PC is not directly accessible from the outside - it is only when you start setting up rules to forward specific ports (and especially all traffic) to an internal IP address on your LAN that you are advised to set up some filters.
