Please change my ip address
Hello i want dynamic ip if possible
Thank you
prichardson
Unfortunatly this is not possible on your current product.
We only provide a Dynamic IP on our Broadband Plus and Broadband PAYG Basic packages.
It is not possible to provide them on our Premier or PAYG packages.
http://portal.plus.net/central/forums/viewtopic.php?t=52025
I now that you have been asked it before, but that is not going to stop me asking again.
Why do you need a dynamic IP address :?:
Chilly
Ok thank you for information.
hitachi
Go on, break the bank,spend a pound a month rather than try to work out ways to get more than your share of the free content.
I now understand why a dynamic IP address is better than static for your usage.
One word of warning about dynamic IP addresses, you are not guaranteed a different IP address every time you reconnect.
It just means that you will not get a static IP address.
Dynamic IP address are often sticky, in that you will be issued the same IP address unless you disconnect for an extended period.
This this may not suit your requirements.
As the previous poster said you may have to stop leaching and pay for access.
Chilly
psk10
If you cant get a Dynamic ip address may be the option is to install a program to block other being able to see it theres a free one you can download from www.proxyway.com
