Playstation 2 using a USB Modem
I have a Ps2, and want to connect it to My broadband connection. However I only have the USB Modem and not a router. I was wondering if I could use an RJ45 crossover cable to connect the ethernet adaptor on the Ps2, to the ethrnet on my laptop. Then run the USB Modem on the laptop and share the connection. What I need to know, is there any software that can assign all bandwidth through the RJ45 port, and assign an IP etc, similar to the setup of a router.
You just have to use ICS with a cross over cable.
It works a treat Wink
Thanx
You get a crossover cable with the PS2 Ethernet adaptor. Please could you tell me how to set this up (settings on PS2 etc). Thanks
