Pipes
dragona
Pipes
ey is there any way to force the connection to a specific pipe?
like my router could i set the default gateway to the IP of the juniper 655 meg pipe? if i had the ip ? i think im on 155 meg pipe 3
Tracing route to portal.plus.net [212.159.8.137]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms mygateway.ar7 [192.168.1.1]
2 69 ms 20 ms 21 ms lo0.plusnet.pth-ag1.plus.net [195.166.128.11]
3 90 ms 66 ms 64 ms gi1-2.vlan3.pth-gw3.plus.net [212.159.1.2]
4 36 ms 71 ms 59 ms gi4-0-23.pth-gw2.plus.net [195.166.129.219]
5 167 ms 127 ms 124 ms atm0-1-0.ptb-gw1.plus.net [195.166.129.246]
6 78 ms 71 ms 113 ms vl4.pri.ptb-gw3.plus.net [195.166.129.226]
7 57 ms 163 ms 137 ms if2.ptb-al1.plus.net [195.166.129.39]
8 107 ms 54 ms 27 ms portal.plus.net [212.159.8.137]
Trace complete.
thanks for reading
Doesnt line number 3 that indicate my pipe or is it line 2?
Pipes
No you cannot determin the pipe that you use. This is something PlusNet control once you enter their network to make sure usage of the pipes is load-balanced, so no individual pipe is overloaded and thus all uses on that pipe getting reduced speeds.
dragona
Pipes
ah mkay thanks anyway
