Ping times
Ping times
Guys,
Does anyone have an idea why my ping times are so poor?
10 15 ms 31 ms 16 ms 116.core.plus.net [212.159.1.116]
11 16 ms 31 ms 16 ms 217.41.128.237
12 187 ms 219 ms 219 ms 217.41.128.132
13 250 ms 641 ms 437 ms 212.56.100.41
Is this to do with my home phone line? As the tracert is only poor on the last hop.
Tia Angus
RE: Ping times
> Guys,
> Tia Angus
Are you trying too do a Peer too Peer game with 212.56.100.41? As it's the one pinging badly, so is whoever got a 56k connection all be it a static IP.
If not 56k then something is wrong their end, if there DSL.
btw you can get a freeware tracer that does a better job than tracert from
http://www.analogx.com/contents/download/network/htrace.htm called Hypertrace
ADSL @ 288/576 Self Install
IRC.UTCHAT.COM
@ in #utgames #utchat #uthelp
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
RE: Ping times
The ip belongs to me at home on ADSL and I was doing a tracert from my work ip, where I'm on a 2mb pipe.
Think it must be my connection to home
Angus
sourceit
RE: Ping times
> Guys,
> Tia Angus
I am getting the same problem, but only accessing sites outside the UK. If accessing outside it goes onto the SprintLink network, which is giving me 95-155ms pings which are rubbish. I have asked PlusNet but been told would get a call or email. None have arrived.
Will wait and see.
Ben Cooper
