Ping spikes
Ping spikes
I'm getting alot of ping spikes up to ~300ms every 20-30 seconds while online gaming, has anyone else these issue atm?
Is there a particular Plusnet server playing up at the moment because my brother (on same exchange and on Plusnet Premier) is fine.
If so how do i find out what Plusnet server i'm using?
btw I'm on Premier 2mb.
TIA
Ping spikes
WinMTR will show where the spikes are and if it's within PlusNets network or outside. Run it for at least 5 mins then post the results.
What is the IP/name of the server you are connected to so I can do a test as well.
Ping spikes
Thanks Peter.
213.208.119.230:27015 is the Counterstrike server i'm trying to play on.
I'll post back with my results.
Ping spikes
Results:-
| WinMTR statistics |
| Host - % | Sent | Recv | Best | Avrg | Wrst | Last |
| 192.168.1.2 - 0 | 401 | 401 | 0 | 0 | 16 | 0 |
| lo0-plusnet.pte-ag2.plus.net - 0 | 401 | 401 | 15 | 25 | 1031 | 15 |
| ge0-0-0-504.pte-gw2.plus.net - 0 | 400 | 400 | 15 | 16 | 62 | 16 |
| gi1-1-22.pte-gw5.plus.net - 1 | 400 | 399 | 15 | 15 | 32 | 16 |
| lon1-9.nildram.net - 1 | 400 | 399 | 15 | 17 | 94 | 15 |
| jolt-gw.nildram.net - 1 | 400 | 399 | 15 | 16 | 47 | 15 |
| 213.208.119.230 - 0 | 400 | 400 | 15 | 15 | 32 | 16 |
Seems to me its a Plusnet issue as lo0-plusnet.pte-ag2.plus.net has a high of 1031 (i noticed a 188 on before i went out the room!)?
I presume thats the Plusnet server i'm connected to? Any chance of me connecting to a different Plusnet server if thats the case?
I'll get my brother to run it as well.
Ping spikes
| WinMTR statistics |
| 192.168.1.2 - 0 | 251 | 251 | 0 | 1 | 16 | 0 |
| lo0-plusnet.ptn-ag1.plus.net - 0 | 251 | 251 | 15 | 25 | 328 | 16 |
| ge0-0-0-103.ptn-gw1.plus.net - 0 | 251 | 251 | 15 | 20 | 47 | 16 |
| gi1-1-22.pte-gw5.plus.net - 0 | 250 | 250 | 15 | 19 | 32 | 15 |
| lon1-9.nildram.net - 0 | 250 | 250 | 15 | 21 | 109 | 16 |
| jolt-gw.nildram.net - 0 | 250 | 250 | 15 | 20 | 62 | 16 |
| 213.208.119.230 - 1 | 250 | 249 | 15 | 20 | 63 | 16 |
This is my brothers results.
Ping spikes
not sure if it's still the case but if you disconnect, leave it for a few minutes and reconnect you should find yourself on a different gateway than pte-ag2 (this may take a few reconnects to do but it should work)
Ping spikes
OK i've disconnected/rebooted a few times but dont know if i had changed server or not but i'll run WinMTR again to check what i'm on this time!
Ping spikes
It is difficult to tell where the problem may lie because between the first and 2nd hop you also have the BT network (between you r router and PlusNet) so It may actually be within BT's network where the spikes are occuring.
Not sure what to suggest as this kind of problem is difficult to diagnose.
I have just run a test to the same IP and had a worse ping of 375ms on pte-ag2.
To pick up a different connection, just discopnnect your router from the BT line, wait a few minutes then reconnect. Although the problem does appear of several PN gateways.
Ping spikes
| WinMTR statistics |
| 192.168.1.2 - 0 | 501 | 501 | 0 | 0 | 32 | 0 |
| lo0-plusnet.ptn-ag1.plus.net - 0 | 500 | 500 | 15 | 18 | 156 | 15 |
| ge0-0-0-103.ptn-gw2.plus.net - 0 | 500 | 500 | 15 | 16 | 63 | 16 |
| gi1-1-22.pte-gw5.plus.net - 0 | 500 | 500 | 15 | 16 | 32 | 16 |
| lon1-9.nildram.net - 0 | 500 | 500 | 15 | 17 | 78 | 15 |
| jolt-gw.nildram.net - 0 | 500 | 500 | 15 | 16 | 63 | 15 |
| 213.208.119.230 - 1 | 500 | 499 | 15 | 15 | 32 | 16 |
|________________________________________________|______|______|______|______|______|______|
Managed to get on ptn and the results are better....will try the game itself now.
Ping spikes
Hmm not 100% perfect but alot better.
I've rerun WinMTR again for longer and its spiked at 547 on lo0-plusnet.ptn-ag1.plus.net
Would this indicate a problem at Plusnet's end? :?
| 192.168.1.2 - 0 | 1365 | 1365 | 0 | 0 | 31 | 0 |
| lo0-plusnet.ptn-ag1.plus.net - 0 | 1365 | 1365 | 15 | 20 | 547 | 15 |
| ge0-0-0-103.ptn-gw2.plus.net - 0 | 1365 | 1365 | 15 | 16 | 78 | 16 |
| gi1-1-22.pte-gw5.plus.net - 0 | 1365 | 1365 | 15 | 15 | 32 | 15 |
| lon1-9.nildram.net - 0 | 1365 | 1365 | 15 | 17 | 94 | 15 |
| jolt-gw.nildram.net - 0 | 1365 | 1365 | 15 | 16 | 63 | 16 |
| 213.208.119.230 - 1 | 1365 | 1361 | 15 | 15 | 32 | 16 |
Ping spikes
Looking at your "average" pings (15-20), I can't see the odd peak being a big problem tbh. I mean the spikes must be pretty rare for you to have such a low average ping.
Captain_Digital
Ping spikes
You think those winmtr results are bad then see these with over 10% packet loss
| WinMTR statistics |
| 192.168.254.254 - 0 | 591 | 591 | 0 | 0 | 10 | 0 |
| lo0-plusnet.pte-ag2.plus.net - 0 | 591 | 591 | 20 | 33 | 180 | 30 |
| ge0-0-0-504.pte-gw2.plus.net - 14 | 591 | 510 | 20 | 30 | 80 | 20 |
| gi1-1-22.pte-gw5.plus.net - 11 | 591 | 527 | 20 | 28 | 60 | 30 |
| lon1-9.nildram.net - 13 | 591 | 518 | 20 | 30 | 191 | 30 |
| jolt-gw.nildram.net - 13 | 591 | 520 | 20 | 30 | 180 | 30 |
| 213.208.119.230 - 13 | 590 | 514 | 20 | 29 | 60 | 30 |
WinMTR - 0.8. Copyleft @2000-2002 Vasile Laurentiu Stanimir ( stanimir@cr.nivis.com )
Ping spikes
:shock:
How come yours are so bad?!
Do u do any online gaming?
Captain_Digital
Ping spikes
Dont do online gaming but was having trouble browseing so did som winmtr traces including the game server you use just for fun. I am getting over 10% packet loss and to www.mcafee.co.uk I am getting over 25
5 packet loss. Have finally getting plus net to look into it and take me seriously.
Ping spikes
Im also getting terrible pings atm through the evenings, dunno what is going on, i used to ping excellent on the game i play.
Pings seem to go back to normal in the early hours of the morning.
| WinMTR statistics |
| 192.168.0.1 - 0 | 407 | 407 | 0 | 0 | 16 | 0 |
| lo0-plusnet.ptn-ag2.plus.net - 0 | 407 | 407 | 0 | 17 | 125 | 15 |
| ge1-0-0-204.ptn-gw1.plus.net - 0 | 407 | 407 | 0 | 15 | 78 | 15 |
| gi1-1-22.ptn-gw5.plus.net - 0 | 407 | 407 | 0 | 14 | 32 | 16 |
| linx-2.router.demon.net - 1 | 406 | 405 | 0 | 22 | 219 | 15 |
| anchor-service-1-s299.router.demon.net - 0 | 406 | 406 | 0 | 18 | 891 | 16 |
| anchor-service-5-fxp0.router.demon.net - 2 | 406 | 400 | 0 | 22 | 1094 | 16 |
| alpha.games.uk.demon.net - 0 | 406 | 406 | 0 | 23 | 969 | 16 |
A few hours later again it sort itsself out. Strange every night pings are high, then gets to a certain time and all goes normal again. FYI i did reconnect and try the new gateway to no avail. Just a certain time and everything works proper again on the ping side.
| WinMTR statistics |
| 192.168.0.1 - 0 | 24 | 24 | 0 | 0 | 0 | 0 |
| lo0-plusnet.ptn-ag1.plus.net - 0 | 24 | 24 | 15 | 16 | 31 | 16 |
| ge0-0-0-103.ptn-gw1.plus.net - 0 | 23 | 23 | 0 | 15 | 16 | 15 |
| gi1-1-22.ptn-gw5.plus.net - 0 | 23 | 23 | 15 | 15 | 16 | 15 |
| linx-2.router.demon.net - 0 | 23 | 23 | 0 | 15 | 16 | 15 |
| anchor-service-1-s299.router.demon.net - 0 | 23 | 23 | 15 | 16 | 31 | 15 |
| anchor-service-5-fxp0.router.demon.net - 0 | 23 | 23 | 0 | 16 | 32 | 15 |
| alpha.games.uk.demon.net - 0 | 23 | 23 | 15 | 16 | 31 | 16 |
Every single server high as hell ping.
