Ping Pong
Ping Pong
I have a friend on Plus.net broadband (just joined) who is having an awful lot of problems with his connection.
I am now reduced to cluching at straws and trying to get to grips with trouble-shooting.
Reading through the forums it seems like a really good idea to try a clean connection to the main BT socket/filter/router, with nothing else plugged into other sockets and using an ethernet cable instead of wireless and conduct the tests on http://www.broadbandreports.com (Line Packet Loss Testing/Tweak Test). Unfortunately all he can do is sporadically receive/send some mail and could not get this far.
I am totally new to all this broadband malarky but pinging looked like a good idea(!) but if I try to ping his IP I get absolutely nothing back (he was on-line when I tried this) I ping my own IP and things happen!
Surely something should come back if his account is working correctly? Or have I not really grasped the subject?
Ping Pong
does his line keep sync or is it droping?
what hardware does he use to connect to the web?
If he has a router , it may be blocking the pings from you, so that would not show a bad sign.
Buz
Ping Pong
Thanks Buz i'll find out tomorrow, i'm taking my laptop & routers/filters over there to see how that responds. My setup was literally plug in and I was connected, absolutely no problems, so i'm baffled!
