Packet length
Packet length
Anybody help? . I have visited many sites and they have referred to this BT problem of packet length. I think you have to set the figure to 1470 or something near this amount. Can any body refer me to a site that will explain this setting.
RE: Packet length
Hi Mitch
No worries mate, relax. You should at lest set MTU to 1458. Go to +net support page and in the right hand framey thng you should see ADSL MTU. Follow this the instructns should be pretty clear.
Any questns, no worries, just ask.
Good luck
Lyndon
RE: Packet length
> Hi Mitch
> Good luck
> Lyndon
Many thanks for the help LYndon..
RE: Packet length
Hi Mitch
No worries. You sorted now?
Cheers
Lyndon
