Packet Loss
Packet Loss
Pinging clarity.jolt.co.uk [195.149.21.11] with 32 bytes of data:
Reply from 195.149.21.11: bytes=32 time=81ms TTL=249
Reply from 195.149.21.11: bytes=32 time=78ms TTL=249
Reply from 195.149.21.11: bytes=32 time=79ms TTL=249
Reply from 195.149.21.11: bytes=32 time=84ms TTL=249
Ping statistics for 195.149.21.11:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 78ms, Maximum = 84ms, Average = 80ms
This has got to be a joke Plusnet. Every time you guys attempt to improve the network...well, frankly speaking it becomes slower than a Lada with NO wheels! I've had ***** ping's and loads of packet loss now for the last two weeks! When will the nightmare end? Thank god you guys have monthly contract options :0
chino
RE: Packet Loss
why don't you try doing a trace route then you can see what / which hop is slowing the overall speed down!
cUnDaLl
RE: Packet Loss
And can you explain the problem again.
Because that shows a packet loss of ZERO. You sent 4 packets and got 4 packets back. Its hardly packet loss.
What i think you mean is ping, in which case im having the same problem.
Dave Allan
RE: Packet Loss
yeah plusnet its really slow, please do sumthing
RE: Packet Loss
> Dave Allan
No, he's right there is packet loss in the plusnet network. All you've done is send four packets. If you send multiple packets ie 10 packets 100 times you will see where the loss is.
for instance pinging portal.plus.net gives:
6% loss at sms.core.telehouse.plus.net
6% loss at jalpiaza.core.telehouse.plus.net
8% loss at delpiaza.core.telehouse.plus.net
10% loss at atm.core.plus.net
4% loss at 250.core01.access.plus.net.uk
5% loss at 230.core01.access.plus.net.uk
4% loss at portal.plus.net
This is pretty good tonight against the loss at weekend and other evenings this week.
