Packet Loss tonight
Packet Loss tonight
Just noticed then when I play Counter-Stike my ping goes between 50 and 250. Hope it's just temporary....
Pinging bbc.co.uk [132.185.132.204] with 32 bytes of data:
Reply from 132.185.132.204: bytes=32 time=93ms TTL=248
Reply from 132.185.132.204: bytes=32 time=54ms TTL=248
Reply from 132.185.132.204: bytes=32 time=131ms TTL=248
Reply from 132.185.132.204: bytes=32 time=254ms TTL=248
Ping statistics for 132.185.132.204:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 54ms, Maximum = 254ms, Average = 133ms
1 REPLY
Re: Packet Loss tonight
Generally, when your transfering data on your line .. you ping times will inrease.. (i.e. when your playing a game/ downloading)
However .. has this just started happening??
Have you made sure you haven't got anything else running in the background..
P2P running ?? / Windows Update / Anti-Virus update / e-mail sending / recieving ??
A trace Route would provide better information to be honest..
Go to a dos prompt and instead of typing "ping www.bbc.co.uk" type "tracert www.bbc.co.uk"
(naturally without the " " )
Tam
[Moderator's note (by acarr): Quote removed. THere is no need to quote the whole of the previous post. This only serves to confuse and make threads un-readable]
