PPPoe or PPPoa
PPPoe or PPPoa
I have a Netgear DG834GUK which one of these settings do I use? I always used PPPoe on a fujitsu ADSL modem but it slows the router down using it so I set it to PPPoa and hey presto! but is this correct?
My MTU is set to 1500 and RWIN 17424 this gives me very acceptable perfomance and speed. Cheesy
PPPoe or PPPoa
PPPoA is what should be used on UK ADSL networks. Any other information like this can probably be found on this page.
PPPoe or PPPoa
Thank you for the quick reply and the info link, all Plusnet tells me in connection details is PPP so I thought I should get this confirmed. Thanks again. Cheesy
