PN Speed test keeps giving a download file size of zero
I've been trying to raise my miserable data download speed of only 2000 or so on a line that syncs at 8128 and for which the MSR is reported as 8000.
(My Linksys router reports 8128 sync, 10dB margin and 34dB attenuation)
I've tried some of the MTU and RWin tweaks discussed elsewhere but although websites load and work fine, the Speedtest will work once (file size 2.93MB) but each time I try to restest, I get a zero byte test file.
So two issues: download rate very slow on a good line after more than 14 days, and what's up with the speedtester? Sad
1 REPLY
ID
the probs i had with the speedtester were sorted by repeated attempts on the RE-TEST button untill it started to work again.
I cant help with the slower speed thou Sad
