PLUSNET HELP! Customer incorrectly profiled.
Dear PlusNet,
Over the last few weeks I have had the usual LLU problem with disconnections that so many of your customers are having.
In parallel, over the last 10 days I have been unable to establish a decent IPSec VPN to my company because you seem to be blocking my encrypted traffic. Nobddy seems to be reacting to this because the ticket that I opened is about LLU.
http://usertools.plus.net/status/archive/1158168848.htm
Dear PlusNet,
Could somebody in PlusNet look at my profile and fix the problem, please?
Taken from your Bandwidth Speed Test application:
15-09-2006 20:34:25 81.7
15-09-2006 20:24:50 396.3
15-09-2006 00:28:17 284.4
13-09-2006 21:52:19 133.6
13-09-2006 21:51:37 129.7
13-09-2006 21:29:27 9.6
Could somebody in PlusNet take a look and check why my IPSec VPN traffic has so little priority?
Exaclty the same problem jasanz, below are my speeds and the ticket I sent to support:
Hello again,
I did some speed checking using the tool from your website and using my laptop while the VPN tunnel was up:
17-09-2006 12:18:17 56
17-09-2006 12:16:59 32
56 and 32!!! Therefore, please check with your engineers whats going on
Hi there.
Unfortunately this thread has been duplicated by the OP in the Community Support forum and indeed has been responded to.
As such I will lock this thread. Cross posting is not permitted as it can cause confusion and duplication.
Thanks.
