PCI card settings
PCI card settings
I have adsl with the PCI card, experienced problems with disconecting until the filters were replaced this seem to of solved that problem, but now I have a problem of loosing my settings.
When shutting down and booting back up my pc the ADSL Head End goes to "Unknown vender" instead of "Alcatel Network Systems inc" I then have to change this back and re-boot again before I can get connected, is anyone else experiencing this problem or know of a solution? Thanks.
RE: PCI card settings
> Hi,
Could be the drivers, especially in XP some have had better results using the older drivers.
You can get most Drivers for the Conexant PCI found on the net at: http://www.themad-house.co.uk/
ADSL @ 288/576 Self Install
IRC.UTCHAT.COM
Usually in #utgames #UT2003chat
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Check out my post on the "ADSL PCI Starter Pack", if it's the ***** Conexant modem that +NET gave you then i'm not in the least bit surprised you're having trouble with it.
I also review this modem here:
http://www.consumer-reviews.co.uk/topic.asp?ReviewID=7174&SubCatID=104276&CategoryID=254&SubMainID=2...
