PCI Modem and Windows XP
Does anyone know if the PCI Modem (Dyanamode A220) supplied by PlusNet works under Windows XP?
It works fine under Windows ME, but the XP Upgrade Advisor says that the ADSL PCI WAN Adapter and ADSL PCI Modem might need new drivers, and that ADSL PCI (in Control Panel) is incompatible with Windows XP.
I have tried the obvious websites, without success.
Any help/info appreciated.
Alan.
RE: PCI Modem and Windows XP
Yes - always worked faultlessly for me on XP Home Edition - I'd just like to know how to get rid of the desktop icons that the install creates (permanently that is and not just until next re-boot).
GA
[snip]
[snip]
I have a Dynamode A220 PCI. It is a connexant chipset, so you need to use the connexant drivers.
They are here;
http://www.themad-house.co.uk/conexant/conexant-drivers.html
Hope that helps
> GA
> [snip]
> [snip]
> Both TweakUI and TweakAll have a facilitry to remove unwanted system desktop icons.
PL
I too am running XP home and have the Dynamode A220 pci modem installed , all works fine.
When windows detects the new hardware , make sure you cancel it and insert the supplied CD .
All the correct drivers for XP are on there.
I noticed that there arent any driver downloads on the Dynamode web site , but im sure someone will know where to find them and any updates that become avaible.
Thanks all for your input, looks like upgrading to XP should be OK.
Cheers.
