PC Anywhere (v9.2) connection through Netgear DG834 Router
We are trying to configure PCAW to come in across the internet. The host is on our LAN with the user on the WAN Side. He is trying to connect to "IP address":5631 or "IP address":5632
However this does not appear to be getting through the router to the remote machine. We know that PCAW works as we can use it through the LAN and also using a dial up connection (which we want to replace)
Any help on corrections I need to make in order to get this to work are much appreciated
Click her to see configuration
link need to be:
http://www.reelin.plus.com/webspace/temp/Netgear.doc
missed out the b in webspace - can you save it as a text file instead?
Sammi
Corrected - file is a doc as it contains screen dumps from the router configuration.
Very easy answer - there was a dial up connection to the internet from the PCAW Host, as well as the LAN connection through the router. Once the Dial Up was removed the connection could be made throught the Router/LAN
