PAYG Broadband speed
I have switched from broadband plus to PAYG £14.99 as I was told by PN that it would increase p2p download speeds (I was getting dialup type speeds). I have since carried out a speed test at http://www.adslguide.org.uk. The results are as follows: (PN speed checker has confirmed the following too)
Speed Test Results
Downstream 500.9 Kbps ( = 0.5 Mbps )
Upstream 372.7 Kbps ( = 0.4 Mbps )
The icon for the ADSL modem in the sys tray says 5.9Mbps.
Why am I not getting 5 to 6 Mbps and what can I do about it?
Thanks.
Pleae keep it simple as I am new to all this.
