P2P software no longer working
Just moved from BT to Plus.net, and have the home2000 package.
It seems that although i have not changed any settings apart from username and pass, none of my p2p sofware will work. I mainly use bittorrents, and i cant seem to connect to any peers.
Any ideas? is p2p blocked somehow?
Please help if you can, Thanks!
Only the HomeSurf accounts have blocks on any of the P2P applications. To confirm, paste a tracert to Google.
In adition, I do occasionaly use both bit-torrant and other P2P apps, and they all work fine.
thats the fastest reply i've ever seen!!
Not at home atm, so will try tonight,
ok, here is the tracert to www.google.co.uk
C:\>tracert www.google.co.uk
Tracing route to www.google.akadns.net [216.239.59.99]
over a maximum of 30 hops:
1 26 ms 19 ms 19 ms lo1.plusnet.pth-ag2.plus.net [195.166.128.6]
2 29 ms 19 ms 19 ms gi1-2.vlan3.pth-gw4.plus.net [212.159.1.3]
3 19 ms 19 ms 27 ms gi5-0-4.pth-gw1.plus.net [195.166.129.21]
4 18 ms 19 ms 29 ms LINX.LON-1-eth110.uk.lambdanet.net [195.66.224.9
9]
5 39 ms 39 ms 39 ms F-2-pos310.de.lambdanet.net [217.71.96.93]
6 39 ms 39 ms 38 ms F-8-eth030-0.de.lambdanet.net [217.71.105.42]
7 38 ms 39 ms 39 ms Google-F.de.lambdanet.net [217.71.111.38]
8 67 ms 69 ms 69 ms 216.239.48.146
9 68 ms 69 ms 68 ms 64.233.174.50
10 69 ms 69 ms 69 ms 216.239.49.114
11 69 ms 69 ms 69 ms 216.239.59.99
Trace complete.
C:\>
any ideas... the actual error i get from bit-torrent is "web request is frelled with an unknown error" what ever that means :/
Hope u can help
Ianwild
Which Bittorent client are you using?
I get great speeds with this one.
Ian
hi, bit torrent is working fine here, i have used the generic, shadow and azureus clients all sucessfully.....not touched kazaa for ages since a mate told me about bt Cheesy
hullo
i havwe just got my ac back up and running and am having major problems getting kazaa or any bittorrent stuff up and runing
is it just me or is it being blocked ?
Which account are you on?
hullo there
i am on the homesurf account (18.99)
just checked on google and it seems that you need to be on selfinstall or any other account besides homesurf to use p2p
its also in the faq on the plusnet website
seems as its so cheap you cant be using it to share large files
but the letter says you can change account so long as you have used up your contract
this must be a new thing though cause i had no problems before !!
AFAIK, the surf accounts have always blocked p2p, and certain other things. Up until now maybe there was some kind of technical fault which allowed you to do so.
