P2P blocked
P2P blocked
Now that P2P is effectively blocked on my old HomeSurf package I'm forced to up/downgrade to Broadband Plus. However, with priority given to less bandwidth-intensive activities, I'm concerned that P2P might be heavily restricted. Can anyone shed any light on the practical effect of any restrictions?
P2P blocked
BB+ Uses traffic shaping in much the same way as your previous account, to prevent P2P, except during the off peak hours.
Wouldn't you be better of upgrading to a premier account? where you can use P2P?
P2P blocked
BB+ is not designed for heavy (or even moderate) P2P users. You need to upgrade to broadband home premier.
topfisher
P2P blocked
Are there P2P restrictions on my ADSL Home Self-Install 512K account?
topfisher
P2P blocked
No need to reply. Found the answer.
