P2P Throttling
P2P Throttling
Does plusnet throttle P2P applications? current maximum is 30Kb?
P2P Throttling
Yes. Just do a search for P2P.
The amount depends on what package you are on and whether you are in the peak or off-peak period. BB+ gets the most, then premier then PAYG the least but they are all affected.
bikepump
P2P Throttling
i can get 200kB/s off-peak (near the max i can have) on premier option 1
