Optimum MTU Size
Optimum MTU Size
I have a netgear ADSL router which i use for connecting to plusnet (just got my account enabled today - woo hoo)
My question to you tech guys is whats the best MTU size - netgear tech support recommend 1458 - but can you confirm this is optimal for plusnet please
- Graham
RE: Optimum MTU Size
> Thanks
> - Graham
Untill BT upgrade their gear 1458 is the correct MTU to use, with a suitable RWIN adjustment.
Reset
Hi Graham,
We have plenty of information avalable regarding MTU values and the optimum sizes within the UK DSL platform.
As stated, we'd advise to set your MTU value to 1458 alll machines that you have on your network or PC.
To do this go to the following URL and run the .exe. file we have available to download.
To change the value back to it's original default (1500) setting just run the file again.
http://www.plus.net/supportpages.html?bvIkeqvfDEk%3D
Best Regards,
Dave Watson.
| David Watson. Unmetered & ADSL solutions
| Technical Support. for Home & Business
| PlusNet Technologies Ltd. @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----- +
