Operation Timeouts
Operation Timeouts
Hi everyone,
Is anyone getting timeouts on any sites? I've been getting timeouts on a few places like E-bay.
Maka.
Operation Timeouts
Think I am having a problem with macromedia
Plusnet Staff
Plusnet Staff
Operation Timeouts
Have you tried Hotmail, MSN or MIcrosoft? If one or more of these don't work then I'd suggest it could be your MTU/RWIN settings. This sort of problem crops up quite a bit with these sites.
If you go to www.dslreports.com you can download a piece of software called DrTCP. There's also details of how to use it on
http://www.kitz.co.uk/adsl/tweak.htm
My recommendation is to set the MTU to 1430 and RWIN to one of the following depending on the speed of your connection
512 = 13900
1Mbps = 27800
2Mbps = 57600
Reboot your equipment and then retry the sites.
