Open recursive DNS server
Fixes: 57
I have just read this thread on ADSLGuide and I admit to being totally confused.
Is this something we should be concerned about.
aljo
You only need to be concerned if you are running a DNS server (you would know if you were as it is only something larger companies do)
Also if you have a router which is running a DNS server (I know some of the Dlink routers have a recursive DNS server enabled in default config)
I've just run a check against what appears to be your IP and it seems not to be recursive unless your offline (21:5Cool
Hope this helps.
Fixes: 57
Thank you for the response. As my router is always on line it appears that I don't need to worry.
