Open Ports
Open Ports
can somebody please tell me the IP Config command that shows all your open ports ?
Regards, John Taylor.
Open Ports
Just run Shields UP! and it will tell you.
Open Ports
Thanks for the reply, I know that, but I would really like to know what the command is. Please, pretty please, pretty please with sugar on it. :lol:
Open Ports
netstat -a will show all open ports.
netstat -ab includes the program using it
netstat /? show other options
You could also download Taskinfo 6 which can show all the ports each process has open along with lots of other networky type info.
Note: the reason i suggested an external test is that ports may be shown as open on the PC but are blocked by your firewall and router so are not actually open to the outside world and thus may give you incorrect info to base any decisions on.
Open Ports
netstat -na tells you what open ports yu have on your machines, if you want to know what services are listening then look for the lines ending with LISTENING
If you have grep on your machine then
netstat -na | grep LISTENING
Mark
Open Ports
Cheers, Thanks very much. A very merry Christmas to you all.
Edit
By the way, what's Grep? Sounds like a fungal infection.
Open Ports
Its a Unix command available for lots of OS's including Windows
http://en.wikipedia.org/wiki/Grep
Open Ports
Thanks, I'll have a read about it.
