On DSL 11 days and . . .
I have been on dsl 11 days now. Things great first few days but gradually have slowed down or even stopped! I have tried in vain to upload my website, but have never completed the procedure due to this problem. Last night I gave up again, with a half uploaded site!! Why oh why does the dsl line disapear in fits and starts, then come back? can't even surf the net properly. Everything is configured correctly. Is DSL all its made out to be? My joy is slowly turning to sorrow.
RE: On DSL 11 days and . . .
You state it slows and stops? When it stops does the light status change on th router?
Is this an ethernet or usb model?
Kind Regards
Kevin
| Kevin Revill ............... Unmetered & ADSL solutions
| PlusNet Customer Support .......... for Home & Business
| PlusNet Technologies Ltd. ....... @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
I also have this problem but only recently within last
3 days net will just cut out completely and as for ftp
, I already raised a ticket due to a corrupt file being on my website which would not let me delete it this was fixed by your guys, thanks for that, but what i did not mention in the ticket was it was caused by the ftp connection constantly dropping out whilst trying to upload my website i would get about 30 files uploaded then connection would break and i would have to repeat the procedure.
I am also a dungeon siege player and in the last 3 days i have not been able to play much as connection just drops without warning, my line synch light and power lights on my router are fine steady at all times ive reset the PC and router with no change in symptoms.
Everything was fine last week, and ive made no changes to my system, from the other postings i see its obviously affecting a lot of people.
I will try to take pings and traceroutes when it gets bad again it seems fine at the moment.
Ali
I lied in my last post the net is awful at the moment
here are a bunch ot traceroutes to 2 common sites with a fair chunk of timeouts.
[root@Faith ali]# traceroute news.bbc.co.uk
traceroute to newswww.bbc.net.uk (212.58.226.30), 30 hops max, 38 byte packets
1 speedtouch (10.0.0.13Cool 1.167 ms 1.086 ms 1.074 ms
2 * plusnet1-hg2.ilford.broadband.bt.net (217.41.128.201) 27.926 ms 27.690 ms
3 217.41.128.162 (217.41.128.162) 26.811 ms 32.821 ms *
4 *
1 speedtouch (10.0.0.13Cool 1.161 ms 1.095 ms 1.071 ms
2 plusnet1-hg2.ilford.broadband.bt.net (217.41.128.201) 29.376 ms 26.868 ms 31.862 ms
3 217.41.128.162 (217.41.128.162) 32.535 ms 32.985 ms 27.899 ms
4 217.41.128.238 (217.41.128.23Cool 30.621 ms 34.898 ms 30.158 ms
5 jalpiaza.core.telehouse.plus.net (212.159.1.113) 32.209 ms 128.514 ms *
6 * * dolpiaza.core.telehouse.plus.net (212.159.1.60) 32.549 ms
7 rt-linx-a.thdo.bbc.co.uk (195.66.224.103) 34.686 ms 37.686 ms 32.860 ms
8 *
[root@Faith ali]# traceroute www.cnn.com
traceroute: Warning: www.cnn.com has multiple addresses; using 64.236.24.28
traceroute to cnn.com (64.236.24.2Cool, 30 hops max, 38 byte packets
1 speedtouch (10.0.0.13Cool 1.185 ms 1.095 ms 1.025 ms
2 plusnet1-hg2.ilford.broadband.bt.net (217.41.128.201) 66.649 ms * 187.011 ms
3 * 217.41.128.162 (217.41.128.162) 31.749 ms 29.566 ms
4 217.41.128.238 (217.41.128.23Cool 31.305 ms 31.518 ms *
5 jalpiaza.core.telehouse.plus.net (212.159.1.113) 41.920 ms * 29.809 ms
6 dolpiaza.core.telehouse.plus.net (212.159.1.60) 35.352 ms 33.516 ms 34.706 ms
7 213.166.3.153 (213.166.3.153) 35.164 ms 32.953 ms 31.715 ms
8 213.232.64.54 (213.232.64.54) 34.638 ms * 31.040 ms
9 * * pos8-0.core2.London1.Level3.net (212.113.0.11Cool 33.973 ms
10 unknown.Level3.net (212.187.131.136) 35.904 ms 32.068 ms 33.106 ms
11 pop2-loh-P2-0.atdn.net (66.185.143.89) 36.188 ms 36.900 ms 31.220 ms
12 bb2-loh-P0-1.atdn.net (66.185.136.242) 32.515 ms 33.494 ms 33.181 ms
13 bb1-new-P5-0.atdn.net (66.185.154.2Cool 110.378 ms * 120.028 ms
14 bb1-ash-P13-0.atdn.net (66.185.152.97) 114.806 ms 109.610 ms 111.090 ms
15 bb2-ash-P2-0.atdn.net (66.185.152.82) 105.858 ms * *
16 * bb2-cha-P7-0.atdn.net (66.185.152.102) 126.598 ms 123.150 ms
17 * bb2-atm-P6-0.atdn.net (66.185.152.61) 123.176 ms 123.932 ms
18 pop1-atl-P5-0.atdn.net (66.185.136.3Cool 120.650 ms 118.996 ms 123.373 ms
19 * *
Kevin,
I have an ethernet PCI. When the dsl stops the lights go out. There can be some or no activity when typing in a new url.
Melanie
> Kind Regards
> Kevin
This light not being on.... What does this indecate according to your manual? Does it mean that the ADSL line is down or something else?
If you reboot your machine does it instantly work again?
Kind Regards
Kevin
No the line is active, it is 'sometimes' just slow at responding. For example trying to upload my website through my ftp client, it just timed out as speed slowed right down and stoped . . . after a few minutes it just starts up again. Does this continuously? !!! Could there be something amiss at my local exchange?
regards,
Melanie
> Kind Regards
> Kevin
I just tried to post my last message, it took all of two minutes to go, hopefully yopu have now received it!
Melanie
Have you tried uploading to ftp-proxy.plus.net?
