Odd problem...
michaelscott
Odd problem...
ADSL was finally activated today! Cheesy I share my connection between two computers using Proxy+ (www.proxyplus.net). However, after setting up my ADSL modem, webpages on the client computer load very very slowly. Far slower than they did when I had 56k. However, file downloads (using HTTP) which along at 56-60kbps.
What could be causing the pages to load so slowly? Even google takes around 15->20 seconds to appear.
Thanks,
Mike
mssystems
Odd problem...
We have used Proxy+ on ADSL without any browsing problems. It was some time ago though.
The only thing I can think of is maybe a MaxConnections setting which is too high or too low. You want it around 8 to 10. You should also uncheck the Use HTTP1.1 through proxy option in IE\Internet Options\Advanced
Regards
Matt
www.mssystems.co.uk
michaelscott
Odd problem...
I fixed the problem by chaning the connection type to [None] Leased Line
The other machine's 'net flys along now...
