OMFG - 300 bytes / second and falling on 1Mb ADSL
Scorpuk
Had to download the WinMTR program on my laptop as I gave up after 2 hours downloading the 256KB file at 200 bytes/second on my 1Mb ADSL connection!!!!
My Traceroute results:
<html><head><title>WinMTR Statistics</title></head><body bgcolor="white">
<center><h2>WinMTR statistics</h2></center>
<p align="center"> <table border="1" align="center">
<tr><td>Host</td> <td>%</td> <td>Sent</td> <td>Recv</td> <td>Best</td> <td>Avrg</td> <td>Wrst</td> <td>Last</td></tr>
<tr><td>No response from host</td> <td> 100</td> <td> 274</td> <td> 0</td> <td> 0</td> <td> 0</td> <td> 0</td> <td> 0</td></tr>
<tr><td>lo1.plusnet.pth-ag2.plus.net</td> <td> 3</td> <td> 273</td> <td> 265</td> <td> 15</td> <td> 29</td> <td> 47</td> <td> 31</td></tr>
<tr><td>gi1-2.vlan3.pth-gw4.plus.net</td> <td> 6</td> <td> 273</td> <td> 258</td> <td> 15</td> <td> 29</td> <td> 47</td> <td> 31</td></tr>
<tr><td>ge1-1-0-23.ptn-gw1.plus.net</td> <td> 6</td> <td> 273</td> <td> 257</td> <td> 15</td> <td> 30</td> <td> 78</td> <td> 31</td></tr>
<tr><td>linx-gw2.ja.net</td> <td> 7</td> <td> 273</td> <td> 254</td> <td> 15</td> <td> 30</td> <td> 47</td> <td> 31</td></tr>
<tr><td>po2-1.lond-scr3.ja.net</td> <td> 5</td> <td> 273</td> <td> 261</td> <td> 15</td> <td> 34</td> <td> 219</td> <td> 31</td></tr>
<tr><td>po6-0.read-scr.ja.net</td> <td> 6</td> <td> 273</td> <td> 257</td> <td> 15</td> <td> 30</td> <td> 47</td> <td> 31</td></tr>
<tr><td>po2-0.bris-scr.ja.net</td> <td> 3</td> <td> 273</td> <td> 265</td> <td> 15</td> <td> 44</td> <td> 235</td> <td> 31</td></tr>
<tr><td>po1-0.bris-bar3.ja.net</td> <td> 5</td> <td> 273</td> <td> 261</td> <td> 15</td> <td> 31</td> <td> 47</td> <td> 31</td></tr>
<tr><td>No response from host</td> <td> 100</td> <td> 273</td> <td> 0</td> <td> 0</td> <td> 0</td> <td> 0</td> <td> 0</td></tr>
</table></body></html>
Started running the plusnet speed tests like half an hour ago and still waitng on it to finish.
Slightly peeved,
John.
[Moderator's note (by Chris P.): Duplicate thread removed. Please do not cross-post, as this merely confuses users since everyone has access to all of the forums. However, I have left a shadow topic in the Customer Feedback topic to insure that the Comms. team see this.]
csogilvie
Hi
You would be better posting your info into http://cgi.support.plus.com/faultreporting/ or posting a plaintext copy rather than HTML copy into the forums.
jberry
If your connection is so slow as to be unusable, and I can see no particular problems with your traceroute, then give us a call and we will be able to test your line for problems.
Regards,
Scorpuk
Maximum Speed Achieved On PlusNet Speedtest: 0.00 kbps
Traceroute Results: http://cgi.support.plus.com/faultreporting/tracert.php?tracertid=3236945
Traceroute Time (24 Hour): 21:30 to 21:45
Traceroute Duration: 15 minutes
Traceroute Packet Size: 64 bytes
Packetloss in Traceroute?: Yes
Exchange: Beith
Problem: Permanently Slow Data Transfer (Everything is slow)
Duration of Problem: Less than 1 week
Minimum Speed Achieved On PlusNet Speedtest: 0.00 kbps
Average Speed Achieved On PlusNet Speedtest: 0 kbps
Account: ADSL Home (Self Install) - 1mb (50:1)
IP Block Size: Single (default)
Ticket Number: None
Additional Information: OMG it really did come back with 0.00kbps on speed test and that was after over an hour waiting!
lol you see no problem with the tracert? I do when I get no response from 1st and last hop!!!!!
Scorpuk
Oh and Mr Colin S. Ogilvie no point posting to that url you gave as the topid has been locked from any further replies!!!!
I have raised a ticket but thats only because nobody on the phone was willing to help me in any shape or form. Pathetic if you ask me!!!!!
First and last hops are just denying Ping replies.
First hop is your router
Last is www.Mirror.ac.uk which is set to block ICMP's aka pings
@ CS better change that default trace url as answer above, guess they got sick of ping's from PN.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Scorpuk
So how come I can goto a dos prompt and get a result when I type ping 10.0.0.2 (which is my reuters IP address)
results are 4 packets sent, 4 re\ceived, 0% packetloss.
Approximate round trip time in miliseconds
minimum=0ms, maximum=34ms, average=7ms
If I run "tracert www.mirror.ac.uk" I get an error:
"Unable to resolve target system name www.mirror.ac.uk"
huh?
Mirror.ac.uk has effectively closed down. Could you try tracerting "www.linx.net" as this is a suitable alternative.
10.0.0.2 is an internal local ip address known only to your network. Your router will allow this probably through a mixture of SPI and NAT. The traceroute was performed from an external host contacting you, whereby your routers firewall would have dropped the ICMP packets... hence no response. Perfectly normal.
