OK ! to Switch PC Off !! ??
joecool
Hi 'am new to this forum, just set up ADSL Hardware, so just like to say hi !! to everyone..................Must say impressed with the support team & quickness via email.............just thought I'd check out the forums !
Firstly after a speed test 'am reaching a speed of 483.80 kbps, is this Ok ?
Also 'am using a usb modem that came with the starter pack , is it Ok to switch of PC if one requires without disrupting any settings etc
Maybe during storms etc or whilst away ?
Also when I click on the 'binatone icon' there's a connect & disconnect, should I always disconnect before switching off PC ?
Sorry if ?? seem basic , trying not to make any mistakes.......
Appreciate any help
Also the 'Plusnet' website seems very informative compared to any others !
Appreciate any help
Thx
yes thats a good speed
yes you can turn of ur PC as the settings are saved so you should not loose them
it does not matter if you disconect before turning off your PC but its always a nice idea Smiley (as when the PC goes off the modem will to and thus disconect you)
Buz
XP closes all connections before its shutsdown. At least my copy does.
joecool
Appreciated guys...............enjoy rest of the w/e Smiley
