Not so static IP address
Up until Wednesday I had the home surf package, and upgraded to the 2Mb Lite account. I thought I still had static IP? Since then I've had the original 80.x.y.z number, a 195.166.128.x number and a 195.166.157.y number. The portal says I have static IP, yet I've had at least three different numbers in three days which to me is hardly static. It's making setting up my SPF records for my domains rather tricky...
Im investigating this for you now.
As far as i can see the only time your ip changed was when you where upgraded to 2MB. There is no reason this should change again.
Hope this helps.
Looking at this a little more closly, are you sure you are looking at the correct information regarding your IP address.
195.166.128.6 and others are actualy the Gateway address for your connection, which can and will change, as there are multiple gateways available for you to connect from (6 plus from memory).
Your IP address should only change once during the conversion.
