Norton slowing down connection speed??
madswitcher
Hi All,
I am sure I saw a post recently regarding a bug in the latest Norton update slowing down connection speeds. I have had a look through the various forums and can't find it. Any ideas or am I having a Saga moment?
Thanks and regards, Mike
1 REPLY
The problem in the past was due to a security certificate expiration which was fixed a few days later. This caused norton antivirus to hang trying to authenticate itself.
I suspect you have something else wrong or misconfigured.
Does the speed increase if you disable the firewall? I.e. it could be the connection not the firewall that is slow.
