Nokia IP55
Nokia IP55
Hi All,
Has anyone any experience of this router? I recently purchased one from eBay (supposedly new, but no manual)
I can't find zip all info on the net, It's all up and working, got that sussed OK, but I want to map some ports in from the outside to my mail server on the inside, I know how to do it, but everytime I try and enable the portmapping system of it, it says it's enabled, but the screen shows disabled and it refuses to show any of my mapped IP's grrrrr...
So, anyone know how to get it working properly, is there a firmware upgrade or at the very least a link to a manual?
Best Regards
Chris
espresso_mick
RE: Nokia IP55
RE: Nokia IP55
Been there, tried that, the links don't work Smiley
But thanks for the reply anyway Smiley
> http://www.adslguide.org.uk/hardware/reviews/2002/q3/nokia-ip55.asp
RE: Nokia IP55
I'd agree with you that there is a certain ammount of difficulty in trying to find anything informative about the router that you have purchased.
However, the best link that I vould locate which contains certain .pdf manuals and config scripts is shown below:
http://www.itchest.co.uk/ip55downloads.asax
Best Regards,
Dave.
Dave Watson.
| David Watson. Unmetered & ADSL solutions
| Technical Support. for Home & Business
| PlusNet Technologies Ltd. @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----- +
