Noisy Line
Fantasticfourum
Noisy Line
As described in my previous post i am having problems with a noisy and bad line that seems to clear itself when i disconnect the phone plug the line sounds clear when nothing is connected. Can i ask a question... can static build up on a line ? or what would cause this problem that can be rectified for a period of time by taking the phone plug out and re inserting it ? I have changed filters but the noises only occure after two or three days HuhHuhHuh Obviously when the line gets bad so does my connection.....Please help anyone Thanks
[Moderator's note by chillypenguin: All CAPS title, changed to lower case.]
1 REPLY
Noisy Line
As you already have a thread running on this subject, lets keep all the responses in one place;
http://portal.plus.net/central/forums/viewtopic.php?t=54443
Chilly
