No one can access web except me?
Hi
Installed Binatone modem last night, did all what the instructions said but I am the only user on our XP Home Ed. who can get in.
We have 5 other accounts (wife and kids) on XP but they all get the same message,
FORBIDDEN 403
and something about you do not have access to control lists.
Can anyone help on this
Many thanks
Richard :?:
Can I ask what ISP you where with, prior to PlusNet?
Some companies like Freeserve, change your proxy settings. The modem installer should remove them, but only on the current account.
"Forbidden" "access control list" sugests that the proxy server is returning this message.
You could try removing any proxies listed under
Tools
Internet options
Connections
Lan Settings
Untick the "use proxy" option.
Yes I was with Freeserve, thanks I'll have a look.
Got to change to wife user acct, so will respond asap.
Richard
Many thanks (acarr)
It worked, you wouldn't believe how long I searched forums etc. for this answer.
Regards
Richard
