No longer connect t newsgroups using wireless?
My laptop cannot connect to the newsgroup servers for some reson, my desktop can.. Laptop is using wireless, desktop ethernet. Im guessing the problem would be somthing to do with my router set up, but im not sure what! Both systems have the same news servers set up, to the letter :|
1 REPLY
Are you running a software firewall on your router. If so does turning it off solve the problem?
I assume you have rebooted your router and laptop?
