No connection for 3 weeks
Hi All,
I haven't got broadband connection for nearly 3 weeks (I think i.e the day they have started to upgrade me from 2 mb to 8mb). I have posted in ADSLGuide and called so many times to cusomer support and still I havn't got any luck with the connection. It is stopping at verifying username stage and giving the message remote computer did not respond. Modem is synchronizing fine but I am not receiving any packets. Can anyone help me as it is 3 weeks by now?
Can't help you! Can give u sympathy have been in same boat for a month what modem/router and system u using?
Speedtouch modem 330
i had the same problem when i got upgraded i hade a bt voyager modem it held the connection for about a minute or so and then steartded training again i borrowed a router of my mate and then there were no problems at all.........check to see if your modem can support faster speeds Smiley
They have downgraded me to 150K user to check whether I will be able to connect or not? Even with low speeds as well I can't connect. Previously I was able to connect upto 2MB without any issues.
I have the same problems with a D-link and Linksys wireless routers/modems ... Its so stressful .... is there anyway we can get our money back? I need to contact Plusnet to get a MAC code (lets me transfer to another ISP) ... anyone done this ? I suppose they're not that helpful ... I wish I hadn't chosen Plusnet ... I will NOT be recommending them to anyone :-(
You have my sympathy. Just had a resolve to my similar problems after more than a month of no connection. See thread:
http://portal.plus.net/central/forums/viewtopic.php?t=43887
Skip to the end for solution to my problem.
Hey guys
Guess what went out and bought a router solved the problem with access Smiley as i can now get connected. However download speeds are very very slow Sad
approx 400 kbps uS. So still a long way to go.
In my very limited opinion I would say that the reason that a lot of people are having these vconnection problems is because the lines are sooooo slow and it drops out because it thinks the server is not responding.....?
What type/make of router did u get ?
