No broadband since Friday evening.
I've had no broadband since Friday evening and it's still not sorted; just wondering if anyone else is experiencing any problems in the Halstead, Essex area?
I'm stuck on a temporary dial-up pony 56k connection.
Have you raised a ticket with support to investigate your problems?
Can you be more specific about your problems, as someone here may be able to help advise you.
Yes, thanks. I rang up on the Friday evening, it's been ongoing since. I just wondered if it was perhaps a regional thing. So maybe there is a problem at the local exchange.
My router is connecting but there appears to be a problem authenticating. I have also tried both test login's that I was sent but neither of those are working either.
I've ran a diagnostic test on my router and the results are this:
Diagnostic Test: Test Complete
Checking LAN Connection
Testing Ethernet LAN connection PASS HELP
Checking ADSL Connection
Testing ADSL Synchronization PASS HELP
Checking Circuit 0 for Network Connection
Test ATM OAM Segment Loop Back PASS HELP
Test ATM OAM End-to-End Loop Back PASS HELP
Test Ethernet connect to ATM PASS HELP
Test PPPoPvc 0 PPPOE connection UNKNOWN HELP
Test PPPoPvc 0 PPP layer connection FAIL HELP
Test PPPoPvc 0 IP connect to PPP SKIPPED HELP
Testing Internet Connection
Ping primary DNS SKIPPED HELP
Query DNS for www.conexant.com SKIPPED HELP
Ping www.conexant.com SKIPPED HELP
Nothing has changed or been altered on my system or router.
Broadband loss
Your are lucky I've been without my Broadband for 8 days now and still nothing is happening. On average It's taking in excess of 11 hours to get a response for my questions. The help and support service is poor to say the least. I'm desperate but don't know who to turn to. My location is Potters Bar, Hertfordshire. Good luck with your problem. :x
