No ADSL since early morning
We have not been able to use our broadband since early this morning. I know there was maintenance between 0630 and 0730 but it is now 1130 and still nothing. This has happened a number of time and we do feel that Plus Net should let us dial up for free on the old 56k as we are paying for a service.
Tried the phone but no one ever answers and you know what this old modem does not seem so slow after all.
Re
Ah it is back now. Switched the Router/modem off then on. Is this what I am supposed to do everytime connection goes down for a while?
Plusnet Staff
Plusnet Staff
You can check the call stats here at present there are 9 calls in queue with an average answer time of under 4 minutes.
Have you shut your ADSL equipment off for an hour? It's possible that you have a stale session and the 1 hour disconnect should clear this.
I'd also try logging in with the BT Test login - bt_test@startup_domain with password set as test if it doesn't reconnect after that, then return to your own username.
Plusnet Staff
Plusnet Staff
Re: Re
In a word yes. Routers have a habit of not being able reconnect everytime after a disconnection. 9 times out of 10 restarting cures this and allows the router to reconnect.
