Night time sync loss
Anybody help with this here are my stats, but what do they mean?
Loss of sync happens between 20:30 - 06:00
I have a Speedtouch Stingray/Green Frog.
ReceiveAttenuation_dB= 55
ReceiveMargin_dB= 6
RxOutputPower_dBm= 0
SendAttenuation_dB= 31
SendMargin_dB= 24
Thanks gav425
shellsong
What are the synch rates?
from 3 up to 3.4 Mbps
Fixes: 57
Basically the snr will always drop overnight for a variety of reasons including street lights and medium wave radio stations.
With an snr of 6db during the day you will get problems overnight.
Your stats are a bit worse than mine but my feeling is that your stable synch speed overnight will probably be closer to 2500 kbps
In my case I get a drop of about 3db overnight from a daytime snr of about 10 db with a synch speed of 3456 kbps
One thing you could try is connecting to the BT Master socket behind the lower plate of an NTE5 BT box. If this gives a big improvement we can suggest things to try.
Here is my over night stats
ReceiveMargin_dB= 5
SendMargin_dB= 24
so the receive margin goes from 6 down to 5 db
There is no change with the front plate off my bt socket and i already use the bt faceplate filter.
Would a router help instead of the USB modem?
If so what one would be best?
gav425
