Night Time Sync loss
Here are my stats in the daytime:
ReceiveAttenuation_dB= 54
ReceiveMargin_dB= 7
RxOutputPower_dBm= 0
SendAttenuation_dB= 31
SendMargin_dB= 22
Sync rate of 3.5Mbps
Now at night here are my stats:
ReceiveMargin_dB= 6
SendMargin_dB= 22
This is when i keep losing sync, I have a filter face plate and only use the master socket. That is right next to my PC, am using a speedtouch stingray usb modem.
Samknows says i am 3.45km straight line distance to my exchange.
Would a router help with over night connection? Would it get a better speed?
Is this router any good?
http://www.ebuyer.com/UK/product/90977
Thanks for your help.
I've never heard of that router, but usually any router is better than a usb modem.
My daytime stats:
d/s sync 4000
SNR 6dB
Attenuation 58-59.
Nighttime stats:
d/s sync anything from 3200 to 3780
SNR 0dB - 6dB
Attenuation 59dB
I used to have a binatone modem, and lost sync if I dropped below 5 dB. My attenuation was 63 dB then.
So I bought a netgear DG834Gv3, the adsl2+ version.
It can hold a signal down to 0 dB (but does lose sync when it goes to negative numbers). Because I have a poor line my attenuation is higher than yours. Until 5 weeks ago I had a 3000 kb/s bras profile, then something happened (don't know what) and now I lose sync a few times in the evening and my profile has dropped to 2.5, thanks to an hour or so of sync under 3424kb/s every evening. But my line stats are much worse than yours.
The two routers I know to have a reputation for holding sync on long lines are Netgear and Linksys, but I've had no experience with the Linksys. Any router is likely to be better than a usb modem, but I'd advise looking at one with a reputation for being able to hold sync at low SNR numbers.
Slipperymack
Hello
The picture they are showing on Ebuyer is the same shell as of a Netgear DG834(any version). Suggest you check out the spec to see if it is a netgear clone.
I have a DG834v2 and my stats go down in the evening as well with the occasional drop in sync.
Although for some reason today I have lost sync quite a few times, (but a router will bring the connection back up immediately), I have raised a ticket about this.
Generally, as stated by alawless,the Netgear holds it sync well and is easy to use.
I have found that the ebuyer modem is a Safecom SART2-4115, are safecom any good?
Its only £19.99 with 5 ports (non wirless) so i think i may give it a try. Will report back with my findings.
