Newsgroups
Newsgroups
Does anyone else have problems with downloading postings in newsgroups? They seem to take ages!
I'm not talking about binaries either, just plain text!
Regards
Rob
eglwys
RE: Newsgroups
> Regards
> Rob
No problem here I can download at over60KB/s from the Plus net newsgroups on ADSL (according to DU meter)
Regards Martin
RE: Newsgroups
I think I may have given a false impression. My download speed is fine, but there is a long pause from when I select a message to it being downloaded and displayed!
It's only a matter of seconds, but it is a matter of seconds on a 1K file!
Anymore ideas?
Rob
fonejacker
RE: Newsgroups
Are you using Outlook Express?
I had a similiar sounding problem and found only one solution - Installing Forte Agent :-)
Regards,
Ian
