Newsgroups
Newsgroups
Can anyone please tell me how I can use "Newsgroups" and how I can access them?
I am particularly interested in the VCD-rip newsgroups...
I have a nasty feeling that on Plusnet we cannot access these... I know that Telewest offer all of alt.binaries.* newsgroups...
Cheers,
Amit
RE: Newsgroups
> Hi,
> Cheers,
> Amit
The very easiest way is to use Googlegroups: http://www.google.co.uk/grphp?tab=wg&q=&ie=UTF-8&oe=UTF-8&hl=en&meta=
RE: Newsgroups
> Hi,
Just use a usenet news program to connect to the server usenet.plus.net
I recommend Forte Free Agent if you're using Windows (see http://www.forteinc.com/main/homepage.php). If you're using Linux I recommend slrn (www.slrn.org).
Plusnet do offer the binary newsgroups, but coverage is patchy and some connection packages do not allow access to the binary groups.
HTH
Jon.
RE: Newsgroups
> > Hi,
> HTH
> Jon.
I assume you want the movies to download, and if you want them off newsgroups be prepared to pay, nothing in this life is for free. What a shame
espresso_mick
RE: Newsgroups
Just add a news account in Outlook Express.
The PlusNet server is news.plus.net
I don't know if there are any VCD groups...never looked, I prefer to pay for original disks and don't like ripping people off.
RE: Newsgroups
If you want to download vcd or dvds then you need MIRC not a newsfeed as that way you get the whole movie. Oftne on a newgroup one part will be missing as it has to be split and often the server hasnt enought room after all a dvd can be well over a gig.
> Hi,
> Cheers,
> Amit
mike001
RE: Newsgroups
Um sorry I mite have read this wrong...BUT you are all wrong...I download 1-2 movies a day from newgroups ...FREE...but you will not doit with plusnet ...the news feed plusnet uses is...well..um C&^%...if you are on freeservce you would not have the same problem as thay have a very good news feed
sorry if I have read this thread wrong ...but I have had a bit to much to drink :-)
