Newbie questions
Newbie questions
I currently dial up on a fax line. Will my fax be able to send/receive faxes when ADSL is installed?
(I suspect yes, but wondered about the likelyhood of interference)
Also are there any pros/cons to the kind of DSL modem? USB external / PCI internal etc...
Neil.
1 REPLY
RE: Newbie questions
> Neil.
A friend of mine in BT Tech Support did say that they have had a few problems when SOME customers use an anologue modem or fax on the ordinary line after it's been setup for ADSL, but not apparently a very heavily reported problem
