Newbie question about the EasyStart package
Does the £27.99 EasyStart package support p2p filesharing?
Thanks.
Smiley
According to the information here
then yes it does.
Thank you for your reply but I read that section and can't see it mentioned, which is why I posted on here.
Thanks.
Yes you can use p2p, this has been confirnmed on the forums previously.
To put your mind at ease however, If you goto the terms and conditions and then choose acceptable use policies it shows that the p2p limitations apply to ADSL HomeSurf only.
Chris
OK - sorry if this has already been answered.
Thanks for the replies.
Smiley
