New house bad line speed
Hi All,
I've just moved my Plusnet account from my old address. I have a 2MB ADSL account but at my new address, am struggling to get up to 1MB. It's a new build house and I am wondering if I should speak to BT or Plusnet support about the line speed. Should I be able to get up to 2MB speeds? Can someone help me with this? I've tried various MTU tweaks but with very little success. The stats from my Belkin router are as follows:
Upstream Fast Channel Data Rate - 288 Kbps
Downstream Fast Channel Data Rate - 1152kbps
Upstream Noise Margin - 25dB
Downstream Noise Margin - 11.5dB
Upstream Output Power - 11dBm
Downstream Output Power - 17dBm
Upstream Attenuation - 31.5dB
Downstream Attenuation - 49dB
Received Superframes Interleaved - 0
Transmitted Superframes Interleaved - 0
Received Superframes Fast - 160348
Transmitted Superframes Fast - 29940
Thanks in advance,
Jeff
Unfortunately your downstream loss at 49dB is outside the limits for 2meg and 1 meg is about the best your going to get until "MaxADSL" comes along.
Limit is 43dB for 2 meg at the moment and is pretty strickly enforced by BT.
even with maxdsl he wont get that much of an improvment Sad
True, even more so considering the downstream SNR is already at 11.5dB and anything below 10dB can result in problematic connections.
Yes I would guess that 1.5 meg will be the most that can be used and still be stable. Sad
BestPump
Ah well. It's a pity the missus loves this new house - I doubt if the slow line speed would convince her to move!
Thanks for the replies guys.
Jeff
