New customer but having problems
Hi, Ive just got connected today and after some trial and error have got connected. I'm using a USRobotics USB 9000 modem and all seems fine only i keep losing my connection now and again.
Anyone got any ideas?
RE: New customer but having problems
Does this look relevant? Hope it helps.
Saturn
Doh!
> Doh!
Check out youre disconnect when idle settings !!!!
> > Doh!
Don't know if this helps (as an addition to the above), but also check your line set-up settings (not too sure where to find this on a US Robotics, but the manual should tell you) - My modem defaults to "Automatic Gdmt or GLite preferred" but I have mine set at Gdmt. I've heard that using ANSI instead of Gdmt can also help. Also check your MTU. If its set to 1500 its too high - try 1458 or 1492. Good Luck!
Voodoomonkee
Today's Benchmark:-Downstream 471 Kbps (58.9 KB/sec) 508 Kbps (inc. overheads)
Upstream 244 Kbps (30.5 KB/sec) 263 Kbps (inc. overheads
> Doh!
Eh?
Brickinit
do you lose your connection when the phone rings or someone rings out? have you got filters on all points connected to phones? worth a check. do a search on this forum using and you will see what i mean
thanks for all the help peolpe. I have all of the above the only thing i'm not sure on is MTU whats that and how can it affect my connection
Go to www.adslguide.com and look up MTU settings it means max transmission unit ie the max size of a packet before its split up (fragmented)
Look for a programme call network optimiser on the BT Pages as well or Dr TCP
Cheers
Jim
