New User - BT lines
New User - BT lines
Hi there
Question
Will this set-up cause me a problem ?
Situration
Have a BT line coming in from outside - goes to a connection box (cable too short !) - split into 2 forwarding cables.
1.1 goes to extension box in my bedroom i.e. where pc is.
2.Other goes to my primary box in the hall
I'm I assuming correct, need to install splitters on both boxes ?
Any feedback most welcome.
Thanks.
N.B.Still at stage where plus.net checking my lines initially.
RE: New User - BT lines
>> I'm I assuming correct, need to install splitters on both boxes ?<<
Thats correct, where there's a phone you'll need a splitter.
> Hi there
> Question
> Situration
> Thanks.
You need to put a splitter only where you connect a phone.
Thanks for comments - so bottom line is:
1.Need add splitter for each box
2.Connection Box should not cause any problems.
If theres a phone plugged into each - yes. otherwise just one splitter @ the point where the phones plugged in.
No
